Contributor I
AP-225 split tunneling showing with Invalid (I) Flag
I've setup AP profile for split tunneling and it's showing with Invalid (I) Flag on Controller, see config below. When I change forward-mode to 'tunnel' all is fine (except split tunneling doesnt work lol;) Please advice
wlan virtual-ap "Aruba-CP-Radius-vap_prof2"
aaa-profile "Aruba-CP-Radius-aaa_prof2"
ssid-profile "Aruba-CP-Radius-ssid_prof2"
vlan 176
forward-mode split-tunnel
aaa profile "Aruba-CP-Radius-aaa_prof2"
authentication-dot1x "CFN-Main-dot1x"
dot1x-default-role "split-usr"
dot1x-server-group "CFN-RADIUS-server-grp"
user-role split-usr
access-list session split-acl
ip access-list session split-acl
any any svc-dhcp permit
any alias Net_10.29.0.0-16 any permit
user any any src-nat
Re: AP-225 split tunneling showing with Invalid (I) Flag
Do you AP configured as RAP or CAP ? Does your AP connected from remote-site/other network ?
if it working as CAP , Split tunneling isnt possible
Split-tunnel is only possible if the AP is configured as a RAP.
Tunnel, bridge and decrypt-tunnel are available when operating as a campus AP.
Tim Cappalli | Aruba Security
Is that a name VLAN ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
Yes, it's CAP...so does it mean I have to change to RAP and then set IKE PSK ? Does RAP connect to controller public IP or  private IP (in my case it's IPsec tunnel from my home remote network to DC firewall - so AP to Controller communication is thru IPsec). I'm not sure what decrypt-tunnel is for
vlan 176 (id 176) is on controller side
(Aruba-7210) #show vlan 176
VLAN CONFIGURATION
VLAN Description Ports AAA Profile
176 VLAN0176 GE0/0/0 N/A
