AP-305 system status led Powersave mode
Hi, I have installed into my network 4 ap model AP-305, but only one show always system status led color "Amber-solid", i don't know why!
The installation guide show this state how "Device Ready: Power safe mode (802.3af) ".
do you know how this ap show always this state?
The ap is connected to Switch HPE OfficeConnect 1920 48G PoE+ (370W), and port show power to 17%.
can you help me, please?
Re: AP-305 system status led Powersave mode
Do you have LLDP enabled on those switchports?  That is typically how the AP negotiates higher power on that port.
yes, i have LLPD enable on my HP 1920, this is "status information" on switch log:
Global LLDP local-information:
  Chassis ID         : d894-03c8-57ce
  System name        : HPE
  System description : 1920-24G-PoE+ (370W) Switch Software Version 5.20.99, Release 1114
Copyright(c)2010-2016 Hewlett Packard Enterprise Development LP
  System capabilities supported : Bridge,Router
  System capabilities enabled   : Bridge,Router
  MED information
  Device class: Connectivity device
  (MED inventory information of master board)
  HardwareRev               : REV.A
  FirmwareRev               : 117
  SoftwareRev               : Release 1114
  SerialNum                 : CN6AGP61Q3
  Manufacturer name         : HPE
  Model name                : HPE 1920-24G-PoE+ (370W) Switch
  Asset tracking identifier : Unknown
LLDP Operating Mode: Txrx
Encapsulation Format: ETHII
LLDP Polling Interval and LLDP trapping is blank
Can you share a show tech from one of the IAPs in this state?
That status can be due to operating in 802.3af reduced power mode.
Check this thread and this section of datasheet:
http://www.arubanetworks.com/assets/ds/DS_AP320Series.pdf
https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-is-the-impact-of-connecting-a-AP-224-or-AP-225-to-POE-802/ta-p/176226
show ap debug system-status | begin Power
will tell you more!
Please check if LLDP  is enabled on the port where AP is connected.
Probably you might have to enable it at interface level.
Hi, the LLPD is already active on my switch HP 1920, but I should enable LLPD on my aruba AP?
in attach show tec on ap where led is amber..
Frequent Contributor I
It is a limitation when use 802.3af. It reduces performance but stills operating.
I saw this before.
Thank you,
Ratchapas S.
From the logs that you have attached,
Power Status
Item Value
Power Supply : POE-AF
LLDP Power : Successfully negotiated at 17.0W
Current Operational State : USB port enabled;
From 300 series datasheet:
http://www.arubanetworks.com/assets/ds/DS_AP300Series.pdf
- Unrestricted functionality with 802.3at PoE
- When using IPM, the AP may enter power-save mode with reduced functionality when powered by an 802.3af PoE source (see details on Intelligent Power Monitoring elsewhere in this datasheet) -
-Without IPM, the USB port is disabled when the AP is powered by an 802.3af PoE source • 
-Maximum (worst-case) power consumption: 13W (PoE) or 11W (DC) - -Excludes power consumed by external USB device (and internal overhead); this could add up to 6.5W (PoE) or 5.5W (DC) for a 5W/1A USB device • 
Hi Singla, ok, but whit my AP is it possibile for you disable IPM?
I have installed a hp 1920 48 port switch dedicated only for my ap, and the power is not my problem!! in this switch i use only 4 port... :-)
I have ap 305 whith this version: 6.5.1.0-4.3.1.0_57768
