AP-365 - OUTDOOR (REACH)
Hello all,
I am doing a project with mesh, but need to clarify a doubt. I saw in the documentation of the Aruba, the AP-365, when activated for use MESH, can communicate with up to 50 meters. It is true? If I have an AP at one point and another to more than 50 meters, both managed to talk?
Re: AP-365 - OUTDOOR (REACH)
Yes, 50 meters should be fine between two AP-365s in a mesh deployment. The environment should still be verified to ensure no unexpected obstructions between the APs, and distances great than 50 meters are possible with the correct conditions.
Charlie Clemmer
Aruba Customer Engineering
I have mesh two AP-365s approx 8m above the ground at 500m without issue.
