Re: APIN0115: Devices dropping from WiFi for about 30 seconds
Ok found it
Is this normal? It's 10.46pm here in Australia so no one is in the office using the WiFi network
40% is  very high for nobody on the network.  You should Make sure that Broadcast Filter ARP is on for all of your SSIDs, first.  See if that makes a difference.
OK So I have checked and there are now users using the WiFi in the office and here are the stats from the APs
One seems to have more users on than the other, is this becuase it power db is stronger than the others?
Also i have checked and I think AP has issues, see screenshot attached
You have two problems:
1.  You are using Wide (bonded) channels in the 2.4ghz
2.  Your transmit power is more than 18.
To fix #1:
Go to RF> ARM and Change Wide Channel Bands to None
To fix#2:
Go to RF> ARM and change Max Transmit Power to 18.  On the same page, also make sure Client Aware is disabled.
Thank you for the reply, I have applied the two fixes, I will be heading to the client office this afternoon and will test with the affected devices
I will report back my findings, thanks again :)
Did you also make sure that on all SSIDs, under Advanced, you have Broadcast Filter ARP?
Yes I changed this last night
Also I have set the following under RF, is this OK?
No.  I would disable ClientMatch on 4.1.3.0
So I can see AP1 is showing alot of noise
