Re: APIN0115: Devices dropping from WiFi for about 30 seconds
But utilization and errors are not high, so it is not something to be worried about at this time.
So I tested the WiFi network with one of the users who was having issues and today everything worked perfectly, thank you for all your help
I still need to test with a few mroe people, I will report back
Go to RF> ARM and change Max Transmit Power to 18.  On the same page, also make sure Client Aware is disabled. what about minum transmit power ???
cjoseph wrote:
You have two problems:
1.  You are using Wide (bonded) channels in the 2.4ghz
2.  Your transmit power is more than 18.
To fix #1:
Go to RF> ARM and Change Wide Channel Bands to None
To fix#2:
To fix #1:
To fix#2:
