Access Point for use in Cafeteria/LGI setting
We are using AP205s for our classroom wireless access, but they are probably not equipped to handle 100-150 users in a LGI or Cafeteria setting.  Assuming 1Gbps link to the switch, and allowing 3Mbps per client, what AP would be good in this setting?
Thank you.
Re: Access Point for use in Cafeteria/LGI setting
225 or 325 would be best suited for a HD area like a cafeteria.
Tim Cappalli | Aruba Security
