Access Point not registering Wireless Controller
  • 1.  Access Point not registering Wireless Controller
    Posted Dec 20, 2014 12:11 PM
    Dear All,
    Hope you all are doing well...
    I have Dell PowerConnect W-7210 Wireless LAN controller (it was Aruba now become dell) and Model: AP-103 I was trying to register my Access point in Wireless LAN controller unfortunately I cannot able to register my Access point in Controller. I can able to ping from controller to network switch ,switch to Access point and from Wireless Controller to Access Point
    Kindly please guide me for solving the issue bcz I am new in Aruba networks..
    Waiting for the reply
    Regards
    Muhammed
  • 2.  RE: Access Point not registering Wireless Controller
    Posted Dec 22, 2014 04:17 AM
    There can be multiple reasons for this,
    Can you see PAPI traffic between AP and the controller ? you can see by using the following command,
    "show datapath session" there should be some traffic with UDP 8211.
    can you see any output when you use "show ap database" , if you can see your AP , what are the flags showing,
    Ex : L -- Unlicensed, E = Regulatory Domain Mismatch, I- Inactive
    Some times status will be " Denied" due to CP sec.
    Please provide me the status and flags so that I can help you fix the issue.
    Please feel free for comeback for any further help on this.
  • 3.  RE: Access Point not registering Wireless Controller
    Posted Dec 22, 2014 11:42 AM
    Thanks bro ..
    I will do all the test and get back to you as soon as posiible
    thanks for helping me i am very happy for this aruba community bcz i am getting very quick reply from here
    regards
    muhammed
  • 4.  RE: Access Point not registering Wireless Controller
    Posted Dec 23, 2014 12:40 AM
    I am closing this thread as it is a duplicate; please see this conversation to add replies.
    Thank you,
    Isadora
