Adding WLAN Guest Voucher Printer to IAP network
in a controller based solution, there is a possibility to generate vouchers for guest access which can be printed out with e.g. Zyxel SP-300E.
Are the same functionalities implemented in an IAP solution as well or are there any differences?
Thnaks and kind regards
Kevin
Aruba
Re: Adding WLAN Guest Voucher Printer to IAP network
That funcaiontlity isn't available today.  In our next reelase, we will have a guest registration login for the VC however, I am not sure what print capabilities will be there
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
