Adding remote branch IAP clusters to Airwave
I'm just getting started with Airwave.  I have about 50 remote sites with IAP clusters.  I have two common SSIDs (Employee and Guest) which are common between each site.  I also have a unique WPA-PSK SSID at each site for RF scanners.  I am currently adding each site as their own group in Airwave and enabling Instant Config within Airwave.  Is this the right way to go about this?  If I wanted to do a mass change across all of the remote site VCs (i.e. changing the admin password) would this be possible with my setup?  Should I have used templates instead?
Re: Adding remote branch IAP clusters to Airwave
You can do groups for common configurations. If most of your sites have a common configuration with only a few differences at each site, you can use a single group and utilize the VC override options in the Instant Config UI
Tim
Tim Cappalli | Aruba Security
Tim,
Thanks for your quick response.  This is exactly what I was looking for.
Further to what Tim has said, I think you should have different groups for different countries.
ACCP, ACCX #817, ACMP, ACMX #294
