AirMagnet Planner Power Settings
What power settings should be used in AirMagnet Planner for the Aruba Access Points?
Re: AirMagnet Planner Power Settings
Hi Ross,
Don't have it in front of me, but in case it's transmit power in dBm, perhaps you can take a look at the AP line up matrix on the Aruba websitw ( http://www.arubanetworks.com/pdf/products/MAT_AP.pdf ) which references that for each AP.
