Airwave Upgrade Firmware Problems
Hi  everyone
  I do upgrade firmware Airwave from 7.6.2 Centos 6.2 Final  to 7.7.14 ,
After,  I cannot  Access Airwave GUI
Pleas tell me about problems
Thx
Re: Airwave Upgrade Firmware Problems
Do this
amp_enable
Be patient, it may take a couple of mins to be accessible.
ACCP, ACCX #817, ACMP, ACMX #294
Super Contributor II
Also browser support has changed in the versions in between, try a newer version of the browser.
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
I'm  try to using command   # less pgsql
Oct 24 23:51:26 CCN postgres[10552]: [1-2] DETAIL:  The data directory was initialized by PostgreSQL version 9.0, which is not compatible with this version 9.2.4.
Oct 24 23:51:26 CCN postgres[10552]: [1-3] LOCATION:  ValidatePgVersion, miscinit.c:1174
Oct 24 23:52:20 CCN postgres[10619]: [1-1] FATAL:  22023: database files are incompatible with server
Oct 24 23:52:20 CCN postgres[10619]: [1-2] DETAIL:  The data directory was initialized by PostgreSQL version 9.0, which is not compatible with this version 9.2.4.
Oct 24 23:52:20 CCN postgres[10619]: [1-3] LOCATION:  ValidatePgVersion, miscinit.c:1174
Oct 24 23:53:13 CCN postgres[10868]: [1-1] FATAL:  22023: database files are incompatible with server
Oct 24 23:53:13 CCN postgres[10868]: [1-2] DETAIL:  The data directory was initialized by PostgreSQL version 9.0, which is not compatible with this version 9.2.4.
Oct 24 23:53:13 CCN postgres[10868]: [1-3] LOCATION:  ValidatePgVersion, miscinit.c:1174
Oct 24 23:53:51 CCN postgres[10988]: [1-1] FATAL:  22023: database files are incompatible with server
Oct 24 23:53:51 CCN postgres[10988]: [1-2] DETAIL:  The data directory was initialized by PostgreSQL version 9.0, which is not compatible with this version 9.2.4.
I see database is not compatible
how to solving problem?
Thx
Try restarting the daemons or server
Thank you
Victor Fabian
Lead Mobility Architect @WEI
you can also attempt to recompile the code
root; make
run this command in screen mode unless you are directly connected to the AMP.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
