LDB
Airwave entry for Longitude and latitude.
While setting up devices in Airwave the fields for longitude and latitude requires a numeric only entry.  I cannot determine the correct method of entry.  Everything I have tried has failed.  There is nothing in the Aruba knowledgebase concerning how to enter this information.
Re: Airwave entry for Longitude and latitude.
have you tried something like for example?
Latitude 43.651256
Longitude -79.384368
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
