All IAPs choosing the same channel in a building
I'm setting up an Aruba Instant cluster on an 8 story building, two APs per floor.
I've noticed that ARM is choosing Channel 1 for every AP in the cluster.
When that happens the clients can no longer connect to the wireless networks. This causes the clients to see many networks on Channel 1.
We tried to solve it by manually setting up the channel on every AP. But after a few hours, the channel was reverted to 1 on most APs.
Have you experienced this issue before?
Re: All IAPs choosing the same channel in a building
What IAP OS version you have installed ?
Are those very close to each other ?
Are users experiencing performance issues?
From the support tab run the ap arm history
Thank you
Victor Fabian
Lead Mobility Architect @WEI
We had two APs located per floor, not very close to each other.
All of them were running 6.2.0.0-3.2.0.4, the issue was solved after we upgraded to 6.2.1.0-3.4.0.2
Aruba
Thanks for posting the current status and REMEDY to your observed issue.
JF
I am experiencing the same issue with 6.4.4.3-4.2.2.0_53034. Does anyone know if it can be fixed with an upgrade again?
Please be specific AND show screenshots of what you are talking about.
I have two IAPs 205 deployed in the same building floor, relatively close to each other.  The issue im presenting is that both AP's are in the same channel.
Your photo is so blurry, that I cannot see anything.
SSH into each AP and type "show ap arm rf-summary" to see why they would be on the same channel:
Channel Summary
channel  retry  phy-err  mac-err  noise  util(Qual)       cov-idx(Total)  intf_idx(Total)
36       0      0        0        96     2/1/1/0/100      12/0(12)        36/0//0/0(36)
40       0      0        0        92     7/7/0/0/100      0/0(0)          0/16//0/0(16)
44       0      0        2        92     10/10/0/0/100    5/0(5)          37/23//0/0(60)
48       0      0        0        92     3/3/0/0/100      13/0(13)        68/12//0/0(80)
52       0      0        0        92     1/1/0/0/100      0/0(0)          0/29//0/0(29)
56       0      0        0        92     1/1/0/0/100      3/0(3)          18/9//0/0(27)
60       0      0        0        92     1/1/0/0/100      5/0(5)          28/25//0/0(53)
64       0      0        0        92     1/1/0/0/100      6/0(6)          33/9//0/0(42)
149      0      0        0        92     3/3/0/0/100      4/0(4)          62/18//0/0(80)
153      0      0        0        92     1/1/0/0/100      10/0(10)        61/21//0/0(82)
157      0      0        0        92     1/1/0/0/100      0/0(0)          3/18//0/0(21)
161      0      0        0        92     1/1/0/0/100      0/0(0)          3/0//0/0(3)
165      0      0        0        96     100/100/0/0/100  0/0(0)          0/0//0/0(0)
1        0      0        0        96     11/9/1/0/99      46/0(46)        225/40//0/0(265)
6        0      0        0        94     23/18/0/0/95     42/0(42)        236/74//0/0(310)
11       0      0        0        94     17/16/0/0/99     36/0(36)        219/40//0/0(259)
Hello, this is the output
Marpico-AP-617# show ap arm rf-summary
Channel Summary
36 0 0 0 97 3/2/1/0/100 5/0(5) 43/0//0/0(43)
40 0 0 0 97 2/1/1/0/100 0/0(0) 25/11//0/0(36)
44 0 0 0 97 3/2/1/0/100 0/0(0) 16/10//0/0(26)
48 0 0 0 97 3/1/1/0/99 0/0(0) 32/6//0/0(38)
149 0 0 0 97 4/2/1/0/99 0/0(0) 51/19//0/0(70)
153 0 0 0 97 2/1/1/0/100 0/0(0) 68/8//0/0(76)
157 0 0 0 97 9/7/1/0/99 0/0(0) 19/19//0/0(38)
161 0 0 0 97 7/6/1/0/100 0/0(0) 19/0//0/0(19)
165 0 0 0 97 3/1/1/0/99 0/0(0) 0/0//0/0(0)
1 0 0 0 73 35/14/4/0/63 0/0(0) 128/53//0/0(181)
6 0 0 0 94 33/20/4/0/91 0/0(0) 121/196//0/0(317)
11 0 0 0 97 34/15/4/0/85 7/0(7) 291/115//0/0(406)
Columns:util(Qual): ch-util/rx/tx/ext-ch-util/quality
HT Channel Summary
channel_pair Pairwise_intf_index
149-153 146
36-40 79
157-161 57
44-48 64
Interface Name :wifi0
Current ARM Assignment :149+/14
Covered channels a/g :0/0
Free channels a/g :0/0
ARM Edge State :disable
Last check channel/pwr :2d:19h:17m:6s/2d:19h:22m:54s
Last change channel/pwr :13d:11h:45m:12s/13d:11h:44m:52s
Next Check channel/pwr :0s/0s
Assignment Mode :Maintain
Interface Name :wifi1
Current ARM Assignment :11/14
Free channels a/g :0/3
Last check channel/pwr :2d:19h:23m:42s/2d:19h:20m:46s
Last change channel/pwr :3d:0h:2m:21s/3d:0h:2m:21s
Channel quality history:wifi0
36:Q: 100 95 100 100 99 99 99 99 98 97 97 99 99 98 99 99 97 97 97 97 99 99 100 98
:c: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
:N: 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97 97
:s: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
:U: 0 0 0 0 1 1 1 1 2 3 3 1 1 2 1 1 3 3 3 3 1 1 0 2
40:Q: 100 100 100 99 99 99 99 99 99 99 99 99 100 99 100 100 100 100 100 100 100 100 98 98
:U: 0 0 0 1 1 1 1 1 1 1 1 1 0 1 0 0 0 0 0 0 0 0 2 2
44:Q: 100 100 100 100 100 99 100 99 99 100 100 99 99 99 100 100 97 97 100 100 100 100 100 100
:U: 0 0 0 0 0 1 0 1 1 0 0 1 1 1 0 0 3 3 0 0 0 0 0 0
48:Q: 99 63 99 99 99 99 99 99 100 99 99 99 98 98 98 98 98 99 99 99 99 99 99 99
:U: 1 1 1 1 1 1 1 1 0 1 1 1 2 2 2 2 2 1 1 1 1 1 1 1
149:Q: 99 99 99 99 99 99 100 100 99 99 98 98 99 99 99 99 99 99 100 100 100 100 99 99
:N: *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97 *97
:U: 1 1 1 1 1 1 0 0 1 1 2 2 1 1 1 1 1 1 0 0 0 0 1 1
:R: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
153:Q: 100 100 100 100 100 100 99 98 98 99 100 100 99 99 99 99 96 96 96 100 100 100 100 100
:U: 0 0 0 0 0 0 1 2 2 1 0 0 1 1 1 1 4 4 4 0 0 0 0 0
157:Q: 99 99 99 99 99 99 100 99 99 99 99 91 99 99 99 100 100 99 100 100 95 100 100 100
:U: 1 1 1 1 1 1 0 1 1 1 1 9 1 1 1 0 0 1 0 0 5 0 0 0
161:Q: 100 100 100 100 95 100 100 99 100 97 100 99 99 99 100 100 100 100 99 99 100 100 100 100
:U: 0 0 0 0 5 0 0 1 0 3 0 1 1 1 0 0 0 0 1 1 0 0 0 0
165:Q: 99 99 99 99 100 100 100 100 99 99 99 100 100 99 99 99 99 100 100 97 100 100 100 100
:U: 1 1 1 1 0 0 0 0 1 1 1 0 0 1 1 1 1 0 0 3 0 0 0 0
Channel quality history:wifi1
1:Q: 63 57 63 76 71 71 82 96 96 96 93 93 57 81 81 69 63 90 78 81 76 58 58 87
:N: 73 73 73 94 86 86 79 91 91 92 88 85 71 77 77 73 73 89 77 82 89 89 76 95
:s: 37 37 37 0 0 0 18 0 0 0 0 0 43 25 25 37 37 0 25 9 0 0 28 0
:U: 17 17 17 24 29 29 4 4 4 4 7 7 13 13 13 26 10 10 19 19 24 42 42 13
6:Q: 91 91 69 91 92 87 79 81 81 81 76 76 76 66 78 97 97 97 97 96 79 79 79 92
:N: 94 94 91 91 94 91 77 83 91 94 92 94 82 88 88 94 94 92 92 92 94 89 89 94
:s: 0 0 0 0 0 0 25 6 0 0 0 0 9 0 0 0 0 0 0 0 0 0 0 0
:U: 9 9 9 9 8 13 17 19 19 19 24 24 24 34 22 3 3 3 3 4 21 21 21 8
11:Q: 85 81 81 86 86 85 86 86 85 85 79 79 94 94 90 90 90 90 86 86 82 34 88 88
:U: 15 19 19 14 14 15 14 14 15 15 21 21 6 6 10 10 10 10 14 14 18 18 12 12
:R: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 66 0 0
Marpico-AP-617#
You might want to consider disabling "Client Aware".  An access point will not change channels if clients are associated and passing traffic, if this is enabled.  If there is severe interference, it will change channels.
Which channel are all of your access points on?
