There is probably a simply solution to this but for the life of me, I can't think of what it is.
So the scenario is: We have a remote location with 60'ish IAPs. Mixture of 204s and 205s. We're trying to set up 3 separate SSIDs for the users on 3 separate VLANs...
Data - VLAN 10 - 10.10.10.x - DHCP is network assigned
Voice - VLAN 20 - 10.10.20.x - DHCP is network assigned
Public - VLAN 30 - 10.10.30.x - DHCP is controller assigned
We have a firewall sitting at the edge of the network that is supposed to direct the traffic based upon IP address, 10.10.10.x and 10.10.20.x go over MPLS... 10.10.30.x out the internet connection.
It hasn't worked since we tried setting it up. While investigating the problem, we noticed that the only IP address that the firewall sees is the Master AP (10.10.10.1). So to the firewall, it thinks all traffic is coming from 10.10.10.1. Makes it hard to segregate off the public traffic!
Why is this happening and how do I correct it? Thanks.
