Amazon TAP
Just wanted to see, if anyone has had issues connectiong the Amazon TAP?  I looked at the specs and only connectes at 2.4 b/g/n.  We have been unable to connect the device to a WPA2-AES PSK networks, with only 20MHz HT enabled.  This is of concern, becasue we have students coming back in less than a month, and they will have TAP/ECHO devices.  Any help would be appreciate and thank you in advance.
Re: Amazon TAP
Mine has no issue connecting on 5 GHz networks. Does it not connect to 5 GHz networks for you?
Tim Cappalli | Aruba Security
Re: Amazon TAP
The Echo support both 2.4/5 GHz, however the TAP only support 2.4.
From Amazon Site:
Amazon Tap connects to public and private Wi-Fi networks (2.4 GHz only) or mobile hotspots that use the 802.11b / g / n standard.
Re: Amazon TAP
Did you enable a user-debug for the MAC address and look at the logs?
