Android Mobile 2.3 can not authenticate with radius
Hi all,
Recently, I deployed 7 APs 115 for my customer. But I have a problem, one client with Android Mobile 2.3.6 (Gingerbread.DXLM3) Baseband I8150DXLM2 can not authenticate with radius 802.1x through radius server on windows server 2008 with every account but when it can authenticate with username/ password (internal database) through SSID Guest Web Portal. My version IAP is 6.4.2.3
Can you help me for it?
Re: Android Mobile 2.3 can not authenticate with radius
Does your NPS server have a public or private CA certificate? Are you using
EAP-TLS, EAP-PEAP, or EAP-TTLS?
Tim Cappalli | Aruba Security
Hi Tim,
My NPS use Public CA with Authentication Property below :
