Occasional Contributor I
Aruba 650 - Evaluation licese doesn't become enabled
Hey Everybody,
i have a little issue with an Aruba 650 controller which i require for a lab setup.
The controller came withou any license on it (except for the POE license) so i generated 3 evaluation licenses ( EVL-2048-AP, EVL-650-PEFV, EVL-RFP-2048) and applied them to the controller. They are accepted by the system, but for some reason they don't become activated and so the APs don't light up at all.
Firmware is: 6.3.1.13
Cheers
Mike
Re: Aruba 650 - Evaluation licese doesn't become enabled
Did you reboot the controller?
Yes. Several times. Also defaulted the controller, set it up from scratch again.
Does the license just say "disabled"?
Yes, they show up in the list as Disabled.
And behind the key there is just no "E" Tag on all of them except the POE License.
Could this be linked to the fact that when i apply the license they are limited to the 64 AP limit the 650 can take?
It just lets you know when you apply licences past the platform limit, but they should work.
If you wipe it out with "write erase all", I would first only try putting in the AP licenses and see if you can bring up an access point.  If you bring up any other licenses, I would not do a "write mem" or "save configuration" until after I rebooted.
OK, i'm going to try that out. But don't i need at least the 3 basic licenses to light up an AP? (AP, PEF, RFP)
It was indeed an issue with the licenses. I've installed only the AP license and when i entered the key it stated that i would have to reboot the controller, which it didn't the other times, but i think i applied the other keys first.
So it seems like the sequence in which you apply the license keys is indeed important.
