Hi!
I have just received an ARUBA 7005 controller and I am first of all trying to test a basic setup without any APs connected through the wired ports. I am initially trying to configure an internal DHCP server to issue addresses through the wired controller ports.
The setup I am trying is as follows:
- Port 0/0/0 - VLAN 1, 192.168.178.10/24
- Port 0/0/1-0/0/3 VLAN 10, 10.0.0.1/24
In VLAN 10, I have configured an internal DHCP Server with the following params:
(Aruba7005) (config) # show ip dhcp database
DHCP enabled
# Test-DHCP-Pool
subnet 10.0.0.64 netmask 255.255.255.224 {
default-lease-time 86400;
max-lease-time 86400;
option domain-name "example.com";
option vendor-class-identifier "ArubaAP";
option vendor-encapsulated-options "192.168.178.10";
option domain-name-servers 10.0.0.1;
option routers 10.0.0.1;
range 10.0.0.65 10.0.0.94;
authoritative;
I do not get any IP address assigned via DHCP, just the auto-configuration assigned by the OS (169...).
I configured the DHCP logging on the controller and noticed the following errors relating to a DHCP relay server.
Mar 19 16:52:56 :202541: <DBUG> |dhcpdwrap| |dhcp| Received DHCP packet from Datpath, sos msg hdr flags 0x42 opcode 0x5a ingress 0x2102 vlan 10 egress 0xa src mac b4:b5:2f:35:0d:cc
Mar 19 16:52:56 :202534: <DBUG> |dhcpdwrap| |dhcp| Datapath vlan10: DISCOVER b4:b5:2f:35:0d:cc Transaction ID:0x420ba973 Options 3d:01b4b52f350dcc 0c:424f5944424f534333 3c:4d53465420352e30 37:010f03062c2e2f1f2179f92b
Mar 19 16:52:56 :202523: <DBUG> |dhcpdwrap| |dhcp| dhcprelay: dev=eth1, length=300, from_port=68, op=1, giaddr=0.0.0.0
Mar 19 16:52:56 :202532: <DBUG> |dhcpdwrap| |dhcp| got 0 relay servers
I am not very familiar with the details of DHCP but it looks to me that the controller is forwarding the DHCP request to a DHCP relay server and not trying to repond to the DHCP request itself.
Can someone help me to resolve the DHCP issue?
