Occasional Contributor I
Aruba AP Model 125
Hi Aruba Support,
Could you tell me AP model 125 how many client can access at the same time.
Getting problem @ our office, Around 15 Clients connect to One AP . Getting slow and slow.
Is there anyway to monitor ?
Is there any configuration need to change ?
Re: Aruba AP Model 125
There is numerous reasons as to what could cause "slow" issues on the network, these issues maybe not even be related at the Wifi layer and somewhere within the wired network.
Are you able to detail what exactly is slow and a little more information on your environment?
If my post addresses your query, give kudos:)
