Aruba Activate Initial Logon Process
  Submitted a request via the Aruba Activate Portal, it is mentioning 2 day time window for my initial logon to be generated, is there any notice when that is complete?  Didn't even get an email that my request was submitted so wanted to see if there was anyway to track that request.  Ordered 12 Instant APs should those all show up upon logon once credentials are created?  Or will I need to register all 12 and wait?  This is our first deployment of the Aruba Instants as our core deployment is leveraging via our on-premise Aruba Controllers.
      Evan Cardanha
Aruba
Re: Aruba Activate Initial Logon Process
Let me check into it....what user ID did you use?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
