Aruba IAP and WIFI Uplink
  • 1.  Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 07:09 AM
    Hello everyone,
    I am trying with little sucess to get my IAP 205 to work with a WIFI uplink to and Apple iPhone. What are the steps for this.
    I only have 1 IAP and I converted this to standalone mode, I turned off extend SSID etc, checked the keys between the IAP and the iPhone host but still nothing.
  • 2.  RE: Aruba IAP and WIFI Uplink
  • 3.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 07:40 AM
    Yes I have done all that. On Instant it says Uplink Type: WIFI-STA Uplink status: Probe
    It does not connect it just falls back to Ethernet
    Type      State  Priority  In Use
    eth0      UP     2         Yes
    Wifi-sta  DOWN   1         No
    3G/4G     INIT   3         No
  • 4.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 09:00 AM
    I have just tired this on an IAP-105 and it works fine. Using and IAP-225 with the latest firmware it won't connect. I have double checked the WPA key and it is correct.
  • 5.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 09:18 AM
    WiFi Uplink is not supported on 802.11 AC access points.
  • 6.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 09:24 AM
    Thanks for the reply. That would explain why it works on a 105 not a 205.
    Where is it documented that it does not work on ac access points.
  • 7.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 09:25 AM
    I have attached a snippet from User Guide in my previous response.
    It is documented in the UG
  • 8.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 26, 2016 10:57 AM
    Is it possible to have an IAP-105 as the VC in a cluster with IAP-205 / IAP-225's and use the IAP-105 to do the WIFI uplink?  Obviously all on the same version of firmware.
  • 9.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 31, 2016 09:50 AM
    that seems to suggest that should be possible, the remark on only the master uses the wifi uplink.
    another question would be, is this a permanent situation of will wifi uplink work on ac APs eventually?
  • 10.  RE: Aruba IAP and WIFI Uplink
    Posted Jan 31, 2016 12:01 PM
    Making the IAP-105 the VC master then using this as the WIFI uplink does not work. I had to make the IAP-105 standalone AP then have 2 virtual controllers.
