Frequent Contributor I
Aruba IAP terminated to Controller but also monitor by Aruba Central
If the IAP terminated to controller (convert to normal Aruba AP), but IT administrator wanna to remotely monitor and manage the AP through Aruba Central. May i know what info will get? It is same as IAP solution (controllerless)?
Valued Contributor II
Re: Aruba IAP terminated to Controller but also monitor by Aruba Central
HI,
No. it can not be monitored through Aruba Central. once we convert it to AP and terminated on the Controller, traffic will go through the Controller. you can monitor it through the controller or through Airwave ( if the Controller is added to Airwave).
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
