Aruba Iap Controller
How to set the date on aruba iap 205 controller?
Re: Aruba Iap Controller
Via ntp server
via cli:
clock set <year> <month> <day> <hour> <min> <sec>
The post above is correct, BUT it is far easier to allow the Instant AP to get a dhcp address.  It will automatically get an ntp time from and then you can set your timezone.  Setting it manually is harder...
Colin Joseph
Aruba Customer Engineering
