Aruba Instant 207 Site Survey Issue
Hello All,
I have a site survey using my Aruba Instant 207 AP, how could i enforce it to work without DHCP, and how to encrease my antinna power to a high power?
Re: Aruba Instant 207 Site Survey Issue
1.  Convert your IAP to standalone mode:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-convert-IAP-to-Standalone-mode-from-CLI/ta-p/2137092
2.  See the detailed instructions in the post here:  http://community.arubanetworks.com/t5/forums/v3_1/forumtopicpage/board-id/unified-wired-wireless-access/page/2/thread-id/549#M62597
Thanks for quick reply :)
Where could i find (Disable SSID on Uplink failure) it is not appeare on the SSID advanced sitting?
I want to transmit the maximum powre from my access point, what is the limit for 2.4 and 5 GHz and from where could i change it?
What version of InstantOS are you running?
You set the Power under RF> ARM.
IAP 207 Firmware : 6.5.1.0 - 4.3.1.0
Please view the photos attached which one of them is the right place to change the antinaa power?
