Aruba Instant Firmware Upgrade
I was looking for a Firmware updgrade matrix with no luck.  Is it fine to upgrade from 6.3.1.1-4.0.0.1 straight to the current available firmware?
Re: Aruba Instant Firmware Upgrade
- Make sure you do it on off-hours.
- Read the release notes thoroughly.  The AP93 (older ap) does not support all new features upon upgrade
- Run it on a sample IAP if you can ahead of time, so you can get used to any new configuration/monitoring pieces
- Test your clients on the new  sample AP to make sure there is nothing you overlooked.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
