Aruba Instant IAP-2250-US with Cisco 3750X-48P-S
PROBLEM: I am trying to get LAG configuration setup on Cisco 3750 for Aruba Instant Access Point IAP-225-US. As I understand it the IAP-225-US has automatic LACP detection and should auto configure for LACP when connected to a switch that is setup for the LAG.
When I log into the IAP, and run the command show lacp status it is telling me that LACP Not Configured.
Cisco 3750X
interface GigabitEthernet1/0/8
 description Aruba_Ether0
 switchport trunk encapsulation dot1q
 switchport mode trunk
 switchport nonegotiate
 speed 1000
 duplex full
 channel-group 2 mode active
end
interface GigabitEthernet1/0/20
 description Aruba_Ether1
 speed 1000
 duplex full
end
interface Port-channel2
 description Aruba_Test_LAG
end
ArubaIAP
wired-port-profile default_wired_port_profile
 switchport-mode trunk
 allowed-vlan all
 native-vlan 1
 shutdown
 access-rule-name default_wired_port_profile
 speed 1000
 duplex full
 no poe
 type employee
 auth-server InternalServer
 captive-portal disable
 no dot1x
 Cisco Status
show eth summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Gi1/0/9(P)  Gi1/0/10(P)
2      Po2(SD)         LACP      Gi1/0/8(I)  Gi1/0/20(I)
Before it setting it to fixed, it was saying status of SD, and the ports were in suspended.
Aruba Status
show lacp status
LACP Not Configured
Valued Contributor I
Re: Aruba Instant IAP-2250-US with Cisco 3750X-48P-S
Can you see if your Cisco switch has a command "no independent-state" for the LAG?
I came across this post, but pretty sure I did everything it suggested...
http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/EtherChannel-between-Aruba-and-Cisco-switch/m-p/130611#M7083
Looking here...
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/12-2_53_se/configuration/guide/3750xscg/swethchl.html
When you configure one end of an EtherChannel in either PAgP or LACP mode, the system negotiates with the other end of the channel to determine which ports should become active. If the remote port cannot negotiate an EtherChannel, the local port is put into an independent state and continues to carry data traffic as would any other single link. The port configuration does not change, but the port does not participate in the EtherChannel.
When you configure an EtherChannel in the on mode, no negotiations take place. The switch forces all compatible ports to become active in the EtherChannel. The other end of the channel (on the other switch) must also be configured in the on mode; otherwise, packet loss can occur.
I'll try channel-group mode on instead of active and do a reload of IAP to see if that fixes it.
Well, I think it's in a LAG, but not LACP....
(config-if)#int range gi1/0/8, gi1/0/20
(config-if-range)#no channel-group 2
(config-if-range)#channel-group 2 mode on
(config-if-range)#end
#show ether sum
        d - default port
2      Po2(SU)          -        Gi1/0/8(P)  Gi1/0/20(P)
 Aruba Status
iap1# show lacp status
LACP Not Configured
You do want mode active.    I did run into a similar issue using the Aruba MAS where LACP would not come up until I set "no independent-state".  Here is a snip of the Aruba config:
interface-profile lacp-profile <NAME>
   group-id 1
   mode active
   timeout short
Once this was set LACP came up on the -225.
I am unsure if the aruba instant product virtual controller has this capability, when I look at the Aruba Instant 6.3.1.1-4.0 User Guide on page 315, it says this...
http://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/Wired_port_profile/lacp_support.htm
every time I try to type a command such as "interface-profile lacp-profile 1", I am getting a %Parse Error....
http://community.arubanetworks.com/t5/Software-User-Reference-Guides/Aruba-Instant-6-4-0-2-4-1-Command-Line-Interface-Reference-Guide/ta-p/168356
The interface profile config snip is for the Aruba switch.   The IAP auto-detects LACP and no configuration is needed on the IAP.
That's what I thought, so what should the ports and port-channel on switch look like to get the Aruba IAP Auto detect to work?
That was a config snip of the LACP config from the switch. With the Aruba switch the command "no independent state" was what got it working for me.  Hopefully there is an equivalent on the Cisco side.
   group-id 1
   mode active
   timeout short
(config-if-range)#channel-group 2 mode ?
  active     Enable LACP unconditionally
  auto       Enable PAgP only if a PAgP device is detected
  desirable  Enable PAgP unconditionally
  on         Enable Etherchannel only
  passive    Enable LACP only if a LACP device is detected
I can switch it back to active, but before it wasn't working...
