Aruba Instant and AppleTv
We are using Aruba 105's in a school enviroment. We have a flat network no VLANs. We are using roles to restrict where a student can get on our network when they are using a device they brought from home. Currently they are allowed Http and Https. The Apple TV is hardwired into our network again Flat Network. Problem is we need the students to be able to connect to the apple tv from their iPads. I have opened every port I can find related to apple Bonjour service and the best I get is a connection that lasts aprox 30 sec.
If someone can point me in the right direction for how to setup to restrict my students by still have apple work it would be very much appreciated.
Oh I am running firmware 6.2.0.0-3.2.0.1_36989
Thanks In advance
Re: Aruba Instant and AppleTv
does it work when you block NO ports?
Yes works great if I leave it open
Moderator
Which ports did you open in the first place?
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
All that was open first was 80 443, 53, and DHCP
Then in an effort to get Aple TV working I have opened
TCP 123, TCP 3689, UDP 5353, TCP 7000, TCP 7001
These were are open to all dest
Sorry not port 7001 its 7100.
You might want to send a quick email to Apple to make sure you are not missing something like ipV6
I found another port in a AirPlay Protocol Document Port 49152. This appears to be the key
Ports I have open now are
TCP 49152
TCP 7000
TCP 123
TCP 3689
TCP 80
TCP 443
TCP 53
UDP 5353
Will update when I has been put to test. :)
I emailed apple and this was the response. I wasn't impressed.
"AirPrint and Apple TV use the Bonjour protocol to communicate. Its not port based. This may help"
They referred me to an Aruba document on AirGroup..
Thanks for your responses in the mean time.
