Occasional Contributor I
Aruba Instant integration with Mikrotik
We are offering one of our customers IAP-305 and they need to confirm if our solution can integrate with Mikrotik solution to assign WLAN sessions for guests (i.e they provide guests with username and password to enable WLAN connection and their WLAN session would only be valid for a determined period of time).
We need to confirm if solution can be integrated with Aruba Instant or if ClearPass should be added for this purpose.
rzz
Contributor II
Re: Aruba Instant integration with Mikrotik
will MitroTiK be used as an external captive portal?
There is a configuration to point captive portal to an external source for both IAP and AP series.
