Aruba Instant retries problem
Hi guys,
I have a IAP 105 network running 6.2.0.0-3.2.0.3_37632 Aruba OS and I found an strange behaviour:
Many of my clients are showing too much retries in/out in the network. There aren´t noise nor interference problems.
Could you help me?
Raúl
Contributor I
Re: Aruba Instant retries problem
Hi Raul,
Check the switch ports that the AP's are connected to.  I saw a similar problem before and it was due to a speed/duplex mismatch between the AP and the switch port that it was connected to.
You should try going to the support tab and running the following commands on that particular AP and the output will give you a better understanding of your RF environment :
AP monitor ap table
AP arm history
AP arm rf summary
AP arm neighbors
Thank you
Victor Fabian
Lead Mobility Architect
Thank you, I checked the switch (it´s and old one) and I changed the port and also I tried to connect directly in the DSL router and the result was the same. I should try to change the physical mode from auto to 1000.
I´m going to run that commands and I will keep you posted,
Raúl
Here is the output of that ARM commands. I attached it as Office table.
 5/31/2013 14:22:00 PM    Target: AP_PB_izq    Command: show ap arm rf-summary
Channel Summary
channel  retry  phy-err  mac-err  noise  util(Qual)     cov-idx(Total)  intf_idx(Total)
36       0      0        0        93     0/0/0/0/95     0/0(0)          0/0//0/0(0)
40       0      0        0        93     5/0/0/0/95     0/0(0)          0/0//0/0(0)
44       0      0        0        93     0/0/0/0/100    8/0(8)          0/0//0/0(0)
48       0      0        0        93     5/0/0/0/95     0/0(0)          0/10//0/0(10)
52       0      0        0        93     0/0/0/0/94     5/0(5)          29/0//0/0(29)
56       0      0        0        93     5/0/0/0/95     0/0(0)          0/19//0/0(19)
60       0      0        0        93     0/0/0/0/94     5/0(5)          28/0//0/0(28)
64       0      0        0        93     5/0/0/1/95     0/0(0)          0/9//0/0(9)
100      0      0        0        93     0/0/0/0/94     0/0(0)          28/0//0/0(28)
104      0      0        0        93     5/0/0/0/95     0/0(0)          0/9//0/0(9)
108      0      0        0        93     0/0/0/0/95     0/0(0)          0/0//0/0(0)
112      0      0        0        93     5/0/0/0/95     0/0(0)          0/0//0/0(0)
116      0      0        0        93     0/0/0/0/95     0/0(0)          0/0//0/0(0)
120      0      0        0        93     5/0/0/0/95     0/0(0)          0/0//0/0(0)
124      0      0        0        93     0/0/0/0/95     0/0(0)          0/0//0/0(0)
128      0      0        0        93     5/0/0/0/95     0/0(0)          0/0//0/0(0)
132      0      0        0        93     0/0/0/0/95     0/0(0)          0/0//0/0(0)
136      0      0        0        93     5/0/0/0/95     0/0(0)          0/0//0/0(0)
140      0      0        0        95     6/0/0/0/94     0/0(0)          0/0//0/0(0)
1        0      0        0        71     10/6/1/0/50    0/0(0)          0/13//0/0(13)
6        38     0        0        94     41/26/11/0/62  18/0(18)        70/11//0/0(81)
11       0      0        0        91     52/49/0/0/97   10/0(10)        65/12//0/0(77)
Columns:util(Qual): ch-util/rx/tx/ext-ch-util/quality
HT Channel Summary
channel_pair  Pairwise_intf_index
116-120       0
52-56         48
100-104       37
124-128       0
36-40         0
60-64         37
108-112       0
132-136       0
44-48         10
Interface Name           :wifi0
Current ARM Assignment   :44+/24
Covered channels a/g     :3/0
Free channels a/g        :15/0
Last check channel/pwr   :7m:3s/5m:55s
Last change channel/pwr  :1d:5h:46m:40s/1d:5h:46m:13s
Next Check channel/pwr   :9s/58s
Assignment Mode          :Single Band
Interface Name           :wifi1
Current ARM Assignment   :6/15
Covered channels a/g     :0/2
Free channels a/g        :0/1
ARM Edge State           :disable
Last check channel/pwr   :2m:37s/5m:50s
Last change channel/pwr  :1d:5h:44m:13s/1d:5h:44m:6s
Next Check channel/pwr   :5m:3s/12s
 5/31/2013 14:22:00 PM    Target: AP_PB_izq    Command: show ap arm history
Interface :wifi0
ARM History
Time of Change       Old Channel  New Channel  Old Power  New Power  Reason
2013-05-30 06:51:21  44+          44+          Max        24         P-
Interface :wifi1
ARM History
2013-05-30 06:53:36  6            6            18         15         P-
2013-05-30 06:53:30  6            6            24         18         P-
2013-05-30 06:53:28  1            6            24         24         Q
2013-05-30 06:51:22  1            1            Max        24         P-
I: Interference, R: Radar detection, N: Noise exceeded, Q: Bad Channel Quality E: Error threshold exceeded, INV: Invalid Channel, G: Rogue AP Containment, M: Empty Channel, P+: Increase Power, P-: Decrease Power, 40INT: 40MHZ intol detected on 2.4G, NO40INT: 40MHz intol cleared on 2.4G, OFF: Turn off Radio, ON: Turn on Radio
 5/31/2013 14:22:00 PM    Target: AP_PB_izq    Command: show ap arm neighbors
ARM Neighbors
bssid              essid           channel  rssi  tx-power  PL (dB)  AP Flags  Last Update (Total updates)
24:de:c6:bf:05:72  WLAN_1E43       6        29    19        101      Passive
24:de:c6:bf:06:c2  WLAN_1E43       6        27    0         0        Passive
24:de:c6:bf:06:92  WLAN_1E43       11       21    0         0        Passive
24:de:c6:bf:02:a2  WLAN_1E43       11       31    0         0        Passive
24:de:c6:be:fa:d2  WLAN_1E43       11       13    19        102      Passive
24:de:c6:bf:05:7a  WLAN_1E43       60       27    0         0        Passive
24:de:c6:bf:06:ca  WLAN_1E43       100      16    24        102      Passive
24:de:c6:bf:06:9a  WLAN_1E43       100      12    24        116      Passive
24:de:c6:bf:02:aa  WLAN_1E43       52       29    9         75       Passive
02:26:f6:90:2b:90  HPB110a.D5E55F  6        5     0         0        Passive
Neighbor Summary:One hop 10 Two hop 0 Current Time: 2013-05-31 13:22:04
Thanks in advance,
Raúl
Looks like this device (possibly a wireless printer near by) might be impacting your connection on channel 6 :
Thank you
Victor Fabian
I knew about that printer and I told my customer to deactivate the WiFi connection... but I can´t believe that this printer could be enough to be the reason of too many retries and connection problems. It should be just an interference problem... Nevertheless I´m going to ask again my customer to deactivate that printer
Raúl
From the support tab try running the following:
AP Monitor AP Table
This command would allow to see which devices are interfering with your IAP
Monitored AP Table
bssid              essid            chan  ap-type      phy-type        dos      dt/mt          ut/it    encr          nstas  avg-rssi  curr-rssi  wmacs  ibss
00:11:22:33:44:55  Linksys           6    interfering  80211b/g-HT-20  disable  543156/536048  0/0      wpa2-psk-aes  0      6         6          0      no
Thank you
Victor Fabian
I don´t see anything wrong...
Monitored AP Table
24:de:c6:bf:05:72  WLAN_1E43  6     valid    80211b/g-HT-20  disable  433308/141481  3/0    wpa-psk-tkip  1      34        34         5      no
24:de:c6:bf:07:1a  WLAN_1E43  44    valid    80211a-HT-40    disable  433308/433308  0/0    wpa-psk-tkip  1      40        40         16     no
24:de:c6:bf:07:12  WLAN_1E43  11    valid    80211b/g-HT-20  disable  433308/433308  0/0    wpa-psk-tkip  8      25        25         18     no
24:de:c6:bf:06:c2  WLAN_1E43  6     valid    80211b/g-HT-20  disable  433307/141548  3/0    wpa-psk-tkip  1      22        26         9      no
24:de:c6:bf:06:92  WLAN_1E43  6     valid    80211b/g-HT-20  disable  433298/33875   3/0    wpa-psk-tkip  1      22        23         4      no
24:de:c6:bf:02:a2  WLAN_1E43  11    valid    80211b/g-HT-20  disable  433281/304960  0/0    wpa-psk-tkip  34     30        30         18     no
24:de:c6:be:fa:d2  WLAN_1E43  11    valid    80211b/g-HT-20  disable  423247/320912  0/0    wpa-psk-tkip  10     9         9          18     no
24:de:c6:bf:05:7a  WLAN_1E43  60    valid    80211a-HT-40    disable  416715/11591   16/0   wpa-psk-tkip  1      23        23         7      no
24:de:c6:bf:06:ca  WLAN_1E43  100   valid    80211a-HT-40    disable  399178/11110   29/0   wpa-psk-tkip  4      13        13         5      no
24:de:c6:bf:06:9a  WLAN_1E43  100   valid    80211a-HT-40    disable  46209/1309     53/1   wpa-psk-tkip  0      0         12         2      no
Start:0
Length:10
Total:10
Any ideas?
Thanks in advance!
Is there any way that your clients can use WPA2-PSK-AES?  Full 802.11n speeds are not supported with WPA-PSK-TKIP
Colin Joseph
Aruba Customer Engineering
