Aruba ap105 firmware
Can anybody send me the latest firmware for the instant ap105?  Having some issues with connectivity to phones.
Thanks, Bob
Re: Aruba ap105 firmware
http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20388
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Joseph, always on top of things here.  Stupid question, but what version do I download, I see a Casiopeia, Centaurus, Pegaasus, Taurus, mibs?
Thanks, Bob
Strange, I didn't get that in my remarks.  Maybe I am in the wrong place.
Thanks, will monitor the update.  Basically all ios devices would have the network drop from the list.  I was able to replicate it by turning wireless on and off a couple of times while connect to the ap-105.  We would have to manually type in the network again after that.  Will see if this firmware fixes the issue.  No other machines seem to have this issue that I know of.
Thans Bob
Colin,
I upgraded my AP105 (non-instant model) to ArubaInstant_Orion_6.4.4.4-4.2.3.2_54910 because I couldn't find an AP105 only firmware......does this firmware cover both the instant and gradual models?
I have several IAP105s up and running with the built in virtual controller, but my AP105 gives me "turn off mobility (20:47:50) !!! Init ---> Slave".
Does this indicate that the IAP105 virtual controller will not control the AP105?
Thank you,
Austin
That indicates that the regulatory domain of the new AP does not match the regulatory domain of the cluster...
Regular Contributor I
How you upgrade non-instant model to instant model as this was never possible, only when having a real instant model you can switch to campus-controller or instant , vice-versa.
wonder why cjoseph didnt gave here feedback or something changed during the last months.
lets dicuss this.
So you own a real instant ap105 model , or is this some plain ap105 normally managed by campus controller?
as far as i know a convert from normal AP to instant-AP can be done in lab by aruba engineering by hard-coding flashing apboot/image , but not by enduser/resellers.
I should have said that message occurs when you try to install Instant Firmware on a Campus AP, which is not supported.
