Occasional Contributor I
Aruba
how to test WIPS in Aruba IAP
Re: Aruba
What are you trying to test? Very vague question.
Tim Cappalli | Aruba Security
Re: Aruba
I am trying to test how to block rogue AP and tried enabling hotspot on the laptop which is connected to IAP. but IAP does not block it.
Re: Aruba
please reply waiting for your sugestions.
Re: Aruba
You should be able to see the other network as Rogue/Interferring.  Containmnet is not on by default.  Depending on what version of code you are on you will need to bring up the IDS configuration.
