Aruba6000 CLI does not show presence of Linecard
Hi -
I have Aruba 6000 Controller running  ArubaOS (MODEL: Aruba6000-US), Version 6.4.4.6
I am working on providing Network Management Application Support for the device. In the process , I need to know the various cards installed on the device
"show slots" does not indicate the presence of a line card  nor the "show inventory".
However , when I do a "show port status" I see a listing of GE ports on the device.
I want to know if there is a way via CLI or MIB query to know the cards ( supervisor & line card ) on the device.
Attaching the o/p of  "show slots" & "show inventory"
(Aruba6000) #show slots
Slots
Slot Status Card Type
0 Present M3mk1
1 Not Present N/A
2 Not Present N/A
3 Not Present N/A
(Aruba6000) #show inventory
Supervisor Card slot : 0
Mobility Processor : FPGA Rev 0x13021320
Mobility Processor Assembly# : 2010027B
Mobility Processor Serial# : F00703416
SC Assembly# : 2010026C (Rev:06.03)
SC Serial# : F00703414 (Date:01/18/08)
SC Model# : Aruba6000-US
Mgmt Port HW MAC Addr : 00:0B:86:61:01:28
HW MAC Addr : 00:0B:86:0A:03:00 to 00:0B:86:0A:03:7F
XPLD Version : (Rev: 20)
PEER Supervisor Card : Absent
Line Card 0 : Not accessible from this SC
Line Card 1 : Absent
Line Card 2 : Absent
Line Card 3 : Absent
FAN 0 : OK, Speed High
FAN 1 : OK, Speed High
FAN 2 : OK, Speed High
Fan Tray Assembly# : 2010007C (Rev:01.00)
Fan Tray Serial# : F02081813 (Date:08/16/11)
Back Plane Assembly# : 2010006B (Rev:02.06)
Back Plane Serial# : A00006020 (Date:01/14/08)
Power Supply type : Power One (400W)
Power Supply 0 : OK (400W)
Power Supply 1 : OK (400W)
Power Supply 2 : Absent
M3mk1 Card Temperatures : M3mk1 card 37 C
: CPU 56 C
AMP Card Temperatures : Processor Card 34 C
: Mobility Processor 50 C
: M3mk1 CPU Fan Speed 6490 RPMs
M3mk1 Card Voltages : M3mk1 5000mV 4950 mV
: M3mk1 3300mV 3340 mV
: M3mk1 2500mV 2508 mV
: M3mk1 1800mV 1780 mV
: M3mk1 1500mV 1490 mV
: M3mk1 1250mV 1260 mV
: M3mk1 1200mV 1200 mV
: M3mk1 IBC 12000mV 11730 mV
: M3mk1 CPU CORE 1200mV 1200 mV
: M3mk1 XGMII VTT 750mV 750 mV
: M3mk1 VTT0(a&b) 900mV 890 mV
: M3mk1 VTT1(c&d) 900mV 890 mV
: AMP 3300mV 3320 mV
: AMP 2500mV 2500 mV
: AMP 1800mV 1800 mV
: AMP 1500mV 1500 mV
: AMP BCM 1200mV 1180 mV
: AMP FPGA 1200mV(1) 1200 mV
: AMP FPGA 1200mV(2) 1200 mV
(Aruba6000) #show port status
Port Status
Slot-Port PortType AdminState OperState PoE Trusted SpanningTree PortMode Speed Duplex
0/0 GE Enabled Up Enabled Yes Forwarding Access 1 Gbps Full
0/1 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/2 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/3 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/4 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/5 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/6 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/7 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/8 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/9 GE Enabled Down Enabled Yes Disabled Access Auto Auto
0/10 XG Enabled Down Enabled Yes Disabled Access Auto Auto
0/11 XG Enabled Down Enabled Yes Disabled Access Auto Auto
Re: Aruba6000 CLI does not show presence of Linecard
The ports you're seeing with "show port status" are the physical ports on the M3 supervisor card, not ports on the line cards. I don't believe the M3 supported use of the line cards, where previous supervisors (Sup1 and Sup2) did. If the M3 did support line cards, it would have been in earlier software prior to AOS 6.
Charlie Clemmer
Aruba Customer Engineering
Hi Charlie -
Thanks for your reply.
Can I populate all the slots with M3 card ? [ if Iam running 6.4.x & above ]
[https://www.cisco.com/c/dam/m/en_us/signaturetool/images/banners/standard/01_standard_ciscoblue.png]
Udaya Bhaskar Chimakurthy
Manager
uchimaku@cisco.com
Tel: +91 44 4052 1359
Cisco Systems, Inc.
SEZ-Unit4, SDB-7, GF,1F-4F ELCOT SEZ Campus, Sholinganallur
CHENNAI
600119
India
cisco.com
[http://www.cisco.com/assets/swa/img/thinkbeforeyouprint.gif]
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
Please click here for Company Registration Information.
Yes
Charlie Clemmer
