ArubaOS vs Instant versions
Hello. I'm new in Aruba community.
In my company we use Aruba AP 207 for wi-fi implementation.
I wanted to know if arubaOS is something different from Instant, because I searched for updates on firmwares and I found different versions for each one.
Thank you.
Contributor II
Re: ArubaOS vs Instant versions
For ArubaOS you also need a controller and licenses.
Most common features are available on both ArubaOS and instant.
If you don’t have a controller use instant, if you have a controller use ArubaOS
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
Contributor I
RE: ArubaOS vs Instant versions
aruba os is the os used for the controller.
The instant version is the os used by APs that are kept in standalone mode.
Normally, the instant AP can also work as a campus AP, but in apboot mode, you can download os from the controller using the command bootcmd tftpboot or convert from gui to campus AP.
Contributor II
update.
All new model AP's will be unified AP's and can function as CAP, IAP or RAP.
Cheers, Frank
