Arubacare part numbers and differences between them
I recently purchased a used IAP. Given that I didn't go through normal channels for purchase, what Arubacare part numbers should I be looking for? My main goal is to make sure that I can get software updates in a timely manner.
When looking around, I see part numbers starting with SN3 and UN3, but I'm unclear as to the differences between them.
thanks
Re: Arubacare part numbers and differences between them
You can get updates in a timely manner on the Limited Lifetime Warranty page here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20388
"DOES THE LIMITED LIFETIME WARRANTY PROVIDE ME WITH ACCESS TO NEW SOFTWARE RELEASES?
Unless otherwise stated, the Limited Lifetime Warranty applies to hardware products only. Aruba Instant Access Points and Mobility Access Switches provide access to the latest shipping software image."  www.arubanetworks.com/assets/faq/FAQ_product_warranty.pdf
