Basic help needed to configure 3g
Hi
I would like to add a 3G dongle to my iap3-wn. I have been reading over the last few days, but I still strucle with some basics......
Where do I find my configure details?
I found out about auto config by country or ISP or manualy.
My USB exist on the supported hardware, but in combination with a wrong country?!  Huawei E180, E1692,E1762 (Optus (Aus)) Do I have any change to get this Huawei operational in Belgium?
Is there any way to get the right details for:
USB type: USB dev: USB tty USB init: USB dial: and USB mode switch?
I expect the auth type, user and password are the details used bij APN ? I was hoping a Huawei would be not to much trouble......... But "Huawei should supply you this details" is not of much help........
Let me explain what I would like to configure:
Just a simple stand-alone AP with 3g uplink.
Plugging in my USB modem, seems to be okay. show cellulair status gives me a notification that modem detected, but no driver installed. When I reboot de ap, without any cellulair parameters, the ap boots, but seems to "stop working" I can no longer connect by wifi.
I include the boot log, anyone whom can help me to get me to de basics??
(if necessery, i do have a few other 3g dongles if this one is choppy :-)
APBoot 1.2.7.4 (build 32721)
Built: 2012-03-08 at 11:37:20
Model: RAP-3x
CPU: AR9344 revision: 1.2
Clock: 560 MHz, DDR rate: 450 MHz, Bus clock: 225 MHz
DRAM: 128 MB
POST1: mem 0 mem 1 mem 2 mem 3 passed
Copy: .... done
Flash: 16 MB
Net: eth0
Radio: ar9344#0
Hit <Enter> to stop autoboot: 2 1 0
Booting OS partition 0
Checking image @ 0xbf100000
Invalid image format version: 0xffffffff
Checking image @ 0xbf800000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
ELF file is 32 bit
Loading .text @ 0x80e00000 (6960088 bytes)
Loading .data @ 0x814a33e0 (32 bytes)
Clearing .bss @ 0x814a3400 (16 bytes)
## Starting application at 0x80e00000 ...
Uncompressing..................................................................
Aruba Networks
ArubaOS Version 6.4.2.6-4.1.1.7 (build 50209 / label #50209)
Built by p4build@tortuga on 2015-05-27 at 08:05:48 PDT (gcc version 4.3.3)
CPU Rev: 2122
934x CPU
flash_size passed from bootloader = 16
arg 1: mem=128M
Flash variant: 16M
ath_sys_frequency: cpu srif ddr srif cpu 560 ddr 450 ahb 225
Cache parity protection disabled
ath_timer_init: plat time init done
Using 280.000 MHz high precision timer. cycles_per_jiffy=560000
Memory: 119552k/131072k available (1698k kernel code, 11368k reserved, 673k data, 6120k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=30027776
LZMA initramfs by Ming-Ching Tiew <mctiew@yahoo.com> ...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................
ATH GPIOC major 0
wdt: registered with refresh
Enabling Watchdog
Talisker RSSI LED initialization
Creating 1 MTD partitions on "ath-nor0":
0x00000000-0x01000000 : "flash"
i2c /dev entries driver
i2c-talisker: using default base 0x18040000
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
Domain Name: instant.arubanetworks.com
No panic info available
Backup ENV.
ATHR_GMAC: RX TASKLET - Pkts per Intr:16
ATHR_GMAC: Mac address for unit 0:8097cbc0
ATHR_GMAC: 00:0b:86:8e:ce:1d
mac:0 Registering S27....
ATHR_GMAC: Mac capability flags : 2400
ATHR_GMAC: Mac address for unit 1:8097cbc0
ATHR_GMAC: 00:0b:86:8e:ce:1e
mac:1 Registering S27....
ATHR_GMAC: Mac capability flags : 2C00
asap_switch: module license 'Proprietary' taints kernel.
Setting PHY...
ADDRCONF(NETDEV_UP): ethsw: link is not ready
Ethernet port 1 mode: active-standby
Ethernet Channel Bonding Driver: v3.0.1 (January 9, 2006)
Setting PHY...
ADDRCONF(NETDEV_UP): eth0: link is not ready
Setting PHY...
bonding: bond0: enslaving eth0 as a backup interface with a down link.
ADDRCONF(NETDEV_UP): eth1: link is not ready
Cfg len is 2.5k
Loading configuration file of length 2.5k...
wifi uplink not present...
extended ssid config detected...
Terminal access enabled...
Telnet server enabled...
Valid SSID detected...
do ethtool autoneg on for eth0
eth1 admin down
eth2 admin down
init usb modem ...
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
SCSI subsystem initialized
usb_storage: Ignoring new-style parameters in presence of obsolete ones
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
Port Status 1c000004
ath-ehci ath-ehci.0: ATH EHCI
ehci_reset Intialize USB CONTROLLER in host mode: 13
ehci_reset Port Status 1c000000
ath-ehci ath-ehci.0: new USB bus registered, assigned bus number 1
ath-ehci ath-ehci.0: irq 3, io mem 0x1b000000
ath-ehci ath-ehci.0: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
USB Device: 0x00000000
USB Product: ATH EHCI
USB Manufacturer: Linux 2.6.16 ehci_hcd
USB SerialNumber: ath-ehci.0
usb usb1: c->desc.bMaxPower 0, udev->busmA 0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb 1-1: new high speed USB device using ath-ehci and address 2
USB Device: 0x12d11446
USB Product: HUAWEI Mobile
USB Manufacturer: HUAWEI
USB SerialNumber: <NULL>
usb 1-1: c->desc.bMaxPower 250, udev->busmA 500
usb 1-1: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
scsi1 : SCSI emulation for USB Mass Storage devices
Vendor: HUAWEI Model: Mass Storage Rev: 2.31
Type: CD-ROM ANSI SCSI revision: 02
Vendor: HUAWEI Model: SD Storage Rev: 2.31
Type: Direct-Access ANSI SCSI revision: 02
1:0:0:0: Attached scsi generic sg0 type 0
sr0: scsi-1 drive
Uniform CD-ROM driver Revision: 3.20
sr 0:0:0:0: Attached scsi generic sg1 type 5
USB Plugged in: Vendor_ID=12d1 Product_ID=1446
USB is not provisoned mannually, goto automatic provision.
parse pre_devid 0x12d11446 isp 0 country 0 apcountrycode BE
parse file /aruba/conf/ModemParams.xml, start with 0, productid is 0x12d11446, isp 0, country 0
find devid 0x12d11446
find multiple device id, please input isp or country to identify a unique parameter.
parsing by AP country code
parse file /aruba/conf/ModemParams.xml, start with 0, productid is 0x12d11446, isp 0, country BE
does not find deviceid, please input advanced usb-modem parameter.
parsing the conflicting list
convert usb type from huawei-cdc to 12
automatic provision success.
USB is provisioned
storage: ignoring vendor id 0x12d1 and device id 0x1506
scsi2 : SCSI emulation for USB Mass Storage devices
scsi3 : SCSI emulation for USB Mass Storage devices
drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.1
SIOCGIFFLAGS: No such device
Starting up in standalone mode
AP xml model 56, num_radios 1 (jiffies 37662)
init_asap_mod: installation:0
radio 0: band 0 ant 0 max_ssid 16
election init: rand=16 HZ=500
IAP client match init
ethernet_device_event: dev eth0 is up
ethernet_device_event: dev ethsw is up
notify asap_mod 3g present...
notify asap standalone ap...
Starting watchdog process...
Getting an IP address...
Dec 31 16:01:16 udhcpc[1700]: udhcpc (v0.9.9-pre) started
Dec 31 16:01:17 udhcpc[1700]: send_discover: pkt num 0, secs 0
Dec 31 16:01:17 udhcpc[1700]: Sending discover...
Dec 31 16:01:18 udhcpc[1700]: send_discover: pkt num 1, secs 1
Dec 31 16:01:18 udhcpc[1700]: Sending discover...
Dec 31 16:01:20 udhcpc[1700]: send_discover: pkt num 2, secs 3
Dec 31 16:01:20 udhcpc[1700]: Sending discover...
Dec 31 16:01:22 udhcpc[1700]: No lease, forking to background.
Dec 31 16:01:42 udhcpc[1756]: send_discover: pkt num 0, secs 25
Dec 31 16:01:42 udhcpc[1756]: Sending discover...
Dec 31 16:01:44 udhcpc[1756]: send_discover: pkt num 1, secs 27
Dec 31 16:01:44 udhcpc[1756]: Sending discover...
Dec 31 16:01:46 udhcpc[1756]: send_discover: pkt num 2, secs 29
Dec 31 16:01:46 udhcpc[1756]: Sending discover...
Dec 31 16:02:08 udhcpc[1756]: send_discover: pkt num 0, secs 51
Dec 31 16:02:08 udhcpc[1756]: Sending discover...
Dec 31 16:02:10 udhcpc[1756]: send_discover: pkt num 1, secs 53
Dec 31 16:02:10 udhcpc[1756]: Sending discover...
Dec 31 16:02:12 udhcpc[1756]: send_discover: pkt num 2, secs 55
Dec 31 16:02:12 udhcpc[1756]: Sending discover...
Dec 31 16:02:34 udhcpc[1756]: send_discover: pkt num 0, secs 77
Dec 31 16:02:34 udhcpc[1756]: Sending discover...
Dec 31 16:02:36 udhcpc[1756]: send_discover: pkt num 1, secs 79
Dec 31 16:02:36 udhcpc[1756]: Sending discover...
Dec 31 16:02:38 udhcpc[1756]: send_discover: pkt num 2, secs 81
Dec 31 16:02:38 udhcpc[1756]: Sending discover...
Picked up default IP a9fe7eea, rand 7eea
Default IP is ready
Dec 31 16:03:00 udhcpc[1756]: send_discover: pkt num 0, secs 103
Dec 31 16:03:00 udhcpc[1756]: Sending discover...
Dec 31 16:03:02 udhcpc[1756]: send_discover: pkt num 1, secs 105
Dec 31 16:03:02 udhcpc[1756]: Sending discover...
Dec 31 16:03:04 udhcpc[1756]: send_discover: pkt num 2, secs 107
Dec 31 16:03:04 udhcpc[1756]: Sending discover...
Dec 31 16:03:26 udhcpc[1756]: send_discover: pkt num 0, secs 129
Dec 31 16:03:26 udhcpc[1756]: Sending discover...
Dec 31 16:03:28 udhcpc[1756]: send_discover: pkt num 1, secs 131
Dec 31 16:03:28 udhcpc[1756]: Sending discover...
Dec 31 16:03:30 udhcpc[1756]: send_discover: pkt num 2, secs 133
Dec 31 16:03:30 udhcpc[1756]: Sending discover...
Dec 31 16:03:52 udhcpc[1756]: send_discover: pkt num 0, secs 155
Dec 31 16:03:52 udhcpc[1756]: Sending discover...
Dec 31 16:03:54 udhcpc[1756]: send_discover: pkt num 1, secs 157
Dec 31 16:03:54 udhcpc[1756]: Sending discover...
Dec 31 16:03:56 udhcpc[1756]: send_discover: pkt num 2, secs 159
Dec 31 16:03:56 udhcpc[1756]: Sending discover...
Dec 31 16:04:18 udhcpc[1756]: send_discover: pkt num 0, secs 181
Dec 31 16:04:18 udhcpc[1756]: Sending discover...
Dec 31 16:04:20 udhcpc[1756]: send_discover: pkt num 1, secs 183
Dec 31 16:04:20 udhcpc[1756]: Sending discover...
Dec 31 16:04:22 udhcpc[1756]: send_discover: pkt num 2, secs 185
Dec 31 16:04:22 udhcpc[1756]: Sending discover...
Dec 31 16:04:44 udhcpc[1756]: send_discover: pkt num 0, secs 207
Dec 31 16:04:44 udhcpc[1756]: Sending discover...
Dec 31 16:04:46 udhcpc[1756]: send_discover: pkt num 1, secs 209
Dec 31 16:04:46 udhcpc[1756]: Sending discover...
Dec 31 16:04:48 udhcpc[1756]: send_discover: pkt num 2, secs 211
Dec 31 16:04:48 udhcpc[1756]: Sending discover...
Dec 31 16:05:10 udhcpc[1756]: send_discover: pkt num 0, secs 233
Dec 31 16:05:10 udhcpc[1756]: Sending discover...
Dec 31 16:05:12 udhcpc[1756]: send_discover: pkt num 1, secs 235
Dec 31 16:05:12 udhcpc[1756]: Sending discover...
Dec 31 16:05:14 udhcpc[1756]: send_discover: pkt num 2, secs 237
Dec 31 16:05:14 udhcpc[1756]: Sending discover...
Dec 31 16:05:36 udhcpc[1756]: send_discover: pkt num 0, secs 259
Dec 31 16:05:36 udhcpc[1756]: Sending discover...
Dec 31 16:05:38 udhcpc[1756]: send_discover: pkt num 1, secs 261
Dec 31 16:05:38 udhcpc[1756]: Sending discover...
Dec 31 16:05:40 udhcpc[1756]: send_discover: pkt num 2, secs 263
Dec 31 16:05:40 udhcpc[1756]: Sending discover...
Dec 31 16:06:02 udhcpc[1756]: send_discover: pkt num 0, secs 285
Dec 31 16:06:02 udhcpc[1756]: Sending discover...
DHCP timed out.
Installing default ip.
Default IP comes up.
ip_time_handler: Got ip and packets on bond0 Started master election 285-0, rand 21
Dec 31 16:06:04 udhcpc[1756]: send_discover: pkt num 1, secs 287
Dec 31 16:06:04 udhcpc[1756]: Sending discover...
DHCP timed out.
DHCP got ip address.
Dec 31 16:06:06 udhcpc[1756]: send_discover: pkt num 2, secs 289
Dec 31 16:06:06 udhcpc[1756]: Sending discover...
169.254.126.234 255.255.0.0
Compressing all files in the /etc/httpd directory...
Dec 31 16:06:28 udhcpc[1756]: send_discover: pkt num 0, secs 311
Dec 31 16:06:28 udhcpc[1756]: Sending discover...
Dec 31 16:06:30 udhcpc[1756]: send_discover: pkt num 1, secs 313
Dec 31 16:06:30 udhcpc[1756]: Sending discover...
Dec 31 16:06:32 udhcpc[1756]: send_discover: pkt num 2, secs 315
Dec 31 16:06:32 udhcpc[1756]: Sending discover...
Done.
Starting Webserver
bind: Transport endpoint is not connected
Launching NTP Client on pool.ntp.org
ath_hal: 0.9.17.1 (AR5416, AR9380, REGOPS_FUNC, PRIVATE_DIAG, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Rights Reserved
ath_rate_atheros: Aruba Networks Rate Control Algorithm
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_spectrum: Version 2.0.0
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserved
ath_pci: 0.9.4.5 (Atheros/multi-bss)
ath_ahb: 0.9.4.5 (Atheros/multi-bss)
ath_ahb: init_ath_wmac
Enterprise mode: 0x00000000
Restoring Cal data from Flash
Reading from Addr: 0xbffe1000
ath_attach: scn 861c0280 sc 86280000 ah 85bc0000
wifi0: Base BSSID 6c:f3:7f:75:7c:50, 16 available BSSID(s)
eth0 address=00:0b:86:8e:ce:1d
br0 address=00:0b:86:8e:ce:1d
wifi0: AP type RAP-3WN, radio 0, max_bssids 16
wifi0: Atheros 9340: mem=0xb8100000, irq=2
Starting FIPS KAT ... Failed FIPS KAT.
AP rebooted Sat Jan 1 00:11:35 UTC 2000; CLI cmd at uptime 0D 0H 11M 35S: reload
shutting down watchdog process (nanny will restart it)...
Completed SW FIPS KAT test
<<<<< Welcome to the Access Point >>>>>
User: process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
i am master now
(00:07:02) !!! Init ---> Master
asap_send_elected_master: sent successfully
