You need an AP license for each AP that the 7005 would serve.
If you do not need the functionality of a hardware controller, you can order instant versions of those access points and one AP will be the virtual controller. If you also order instants, you would have the option to convert them to campus APs later, so that they would work with a 7005 controller.
