DSP
Contributor II
CGIWrap Error: Script dir not found - External CP - Instant
Hello Experts,
I am running Instant cluster of IAP 105
Version:
6.4.2.3-4.1.1.2_48114
When connecting to the Guest SSID and opening the browser instead of showing the Captive portal to accept the T&C the browser (Chrome) is showing this error :
The specified user does not have a script directory set up for execution of cgi scripts, or the directory permissions prevent cgiwrap from using that directory.
Server Data:
Server Administrator/Contact: webmaster@xxxx.xx.xx
Server Name: www1.XXXX.XX.XX
Server Port: 80
Server Protocol: HTTP/1.1
Virtual Host: www1.Xxxxx.xx.xx
Request Data:
User Agent/Browser: Mozilla/5.0 (Windows NT 6.3; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/40.0.2214.93 Safari/537.36
Request Method: GET
Remote Address: X.X.X.X
Remote Port: 46910
Extra Path Info: /XXXX/XXXX/index.php
I am trying to test this with different browser and will post it later. ( not on site )
The CP is external to the VC and in somehow I am concerned this may imply an attempt to execute a unathorised script on the server. There are unrestricted access rules to the SSID. As long as I know we weren't getting this message on previous versions.
Has anyone faced the same situation ? The CP use to show ok on previous versions.
Client OS is Windows 8. After this error is displayed the can browse the internet normally.
Saludos,
David
