Contributor I
Can 802.11 wireless packages on IAP be de-crypted to troubleshoot an ARP issue?
Hi all,
We are having ARP issues on our IAP105 environment (managed by Airwave).
We are tracing as much as possible, also on wireless packages, just to be sure that ARP messages are actually leaving the wireless device. We use the remote pcap command on the IAP cli.
pcap start BSSID @IPofcomputer UDPPort format size
However, the packages are of course 802.11 encrypted. Is there any way to de-crypt the packages so we can see the ARP packages?
Thanks for you help!
Re: Can 802.11 wireless packages on IAP be de-crypted to troubleshoot an ARP issue?
What encryption are the client devices using?
Can you install wireshark on the client device?
Besides mirroring the port the ap is connected to, have you tried the 'debug pkt' command set?
debug pk type arp
debug pkt dump
ACCP, ACCX #817, ACMP, ACMX #294
Contributor I
Encryption is EAP-TLS
Installing Wireshark is difficult since we can't predict where the problem is going to occur next. We are trying to get netsh tracing on all clients.
Contributor I
What does this do exactly?
It dumps those packet types onto the console.  This includes packets from wireless clients and packets that it is seeing on the wire.
Not as good as a wireshark...but the next best thing.  Try it.  It's pretty neat.
Not sure what code this started on, so if you are on an older version, it may not work.
