Occasional Contributor I
Can I mix iap-215 with iap-225 and them with different virtual-controller-country?
Can I mix iap-215 with iap-225 in the same VC and those IAPs have different virtual-controller-country one is US and the other one is RW? additionally both IAP's have the same ArubaOS version: 6.4.2.6-4.1.1.11
After I tried i got this message: <WARN> |AP xx:xx:xx:xx:xx:xx@x.x.x.x cli|  AP not allowed, turn off master election
Thanks for your feedback
Re: Can I mix iap-215 with iap-225 and them with different virtual-controller-country?
No, they need to be set to the same country code.
Sent from Nine
Tim Cappalli | Aruba Security
Ok Tim, thanks for your answer...
Regards
