Can I use a USB modem with a RAP3 NOT in Instant Mode?
I'm new to setting up RAP units, but I have acquired a couple of RAP3 units that will be managed by my 3200 controller.  I have successfully converted them from Instant and have them working with controller over a wired Internet connection, but I'm wondering how I go about using a 3G connection (either as primary or backup) in this configuration.  Is it even possible?
Thanks!
Jeff Wade
Re: Can I use a USB modem with a RAP3 NOT in Instant Mode?
Yes. See here in the user guide:
http://www.arubanetworks.com/techdocs/ArubaOS_6.4.4.x_WebHelp/Web_Help_Index
.htm#ArubaFrameStyles/Remote_AP/Support_for_4G_USB_Modem.htm
Tim Cappalli | Aruba Security
