Can IAP 205 work along with IAP 275 and IAP 93 in same cluster ?
Can Virtual controller IAP 205 work along with IAP 275 and IAP 93 in same cluster
What will be the prerequsites ?
IAP 205 and IAP 275 are ac Radio how they work in an single cluster with bgn IAP 93?
Re: Can IAP 205 work along with IAP 275 and IAP 93 in same cluster ?
Yes they can but keep in mind that the cluster size will be limited to 16 IAPs due to the 93 being a member of the cluster.
Tim
Tim Cappalli | Aruba Security
Valued Contributor II
Adding to TIm, you need to update the Image manually or through Airwave coz these are of different Hardware platform. one more thing, AP 93 will not support Mesh due to single radio :)
Hope got some more clarity on this.
Cheers,
Venu Puduchery,
