- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
07-12-2013 11:36 AM
hi guys,
just was wondering if I can inject some IAPs into the existent network, which already has an amc3200 and a bunch of AP-93s configured as RAPs. All that is supposed to be within the same vlan/broadcast domain.
what would be the consequences ? can these two technologies remain as two separate entities?
thanks.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-15-2013 07:49 PM
Yes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Can IAP coexist with CAP/RAP on the same L2
07-16-2013 11:39 AM
Much appreciated for the answer.
I was afraid that IAPs will discover the controller and will join it and eventually will get converted to RAPs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-16-2013 11:50 AM
If they are broadcasting different ssids then that should be fine, though the controller will see them as rogues.
ACCP, ACCX #817, ACMP, ACMX #294
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-16-2013 11:53 AM
what would be the issue with the same SSID, since I'm planning to have exactly that ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-16-2013 03:28 PM
No issue unless you're automatically attempting to prevent rogues.
The WIPS functions from either set of access points will try to block use of the other if you've got it turned on.
If not, you'll just get warnings from each that the other may be a rogue.
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-16-2013 04:05 PM
Might be issues with clients roaming between the two systems. Will be somewhat worse for dot1x or captive portal users.
At least make them use the same subnet and dhcp server so there's no chance of duplicate ips etc.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-19-2013 06:26 AM - edited 07-19-2013 06:29 AM
no dot1x and the captive portal is going to be external, and on top of that the subnet for the users is going to be the same with the same DHCP, so I guess I should be fine. In regards of rogue APs detection, I guess I can define which APs are not rogue so I don't get the alarms.
thanks guys for good advise.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
07-19-2013 07:21 AM
You can change Rogue status on the Controller but you cannot on the IAP.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
