Can We creat a cluster of IAP-225 and IAP-175
Hi I had a doubt that can we make a single cluster of virtual controller using IAP-225-RW and IAP-175P
Re: Can We creat a cluster of IAP-225 and IAP-175
Is the IAP-175 RW or US?
Tim Cappalli | Aruba Security
IAP-225-RW is for Rest of the World  except US
IAP-175RW is not there IAP-175P is an outdoor Access Point
Contributor I
I think there should be no problem to build the cluster.
According to the Data Sheets of the APs i found the following:
AP-225-RW:
Aruba Instant IAP-225 Wireless Access Point, 802.11ac, 3x3:3, dual radio, integrated antennas – Restricted regulatory domain: Rest of World
AP-175-P:
Aruba Instant 175 outdoor wireless AP, 802.11a/b/g/n, 2x2:2, dual radio, external antenna connectors, 802.3at PoE+. Includes mounting kit and sun shield. These products should be considered rest-of-world products and must not be deployed in the United States, Japan or Israel.
Thomas
Systems-/Network-Engineer
ACMP, ACCP, Brocade Certified
Moderator
Is your intent to do wireless Mesh between the nodes?  IAP-225 (and IAP-27x) currently do not support Mesh.  Otherwise, it should be fine.
