Can a IAP205H be used with an IAP225 Virtual Controller ?
Aruba newbie...
I currently have several IAP225s managed by a single Virtual Controller. Can I use this same V.C. to also manage IAP205Hs?
Re: Can a IAP205H be used with an IAP225 Virtual Controller ?
Yes , just need to make sure it has the same version of code as you current IAP225 cluster
Thank you
Victor Fabian
Lead Mobility Architect @WEI
When you mention "same version of code" do you mean same firmware version?
Yes , make sure it is before you join it to the cluster
Thank you
Victor Fabian
Tried getting to the software download section to get the latest so that both my iAP225 cluster and new iAP205H have the same firmware but I don't have that option on my Aruba web page.
I'm suppose to see a Dowlonad Software tab under which these downloads are located but it's no longer there.
Has it been moved?
Got access to the firmware section and downloaded the latest version for the 205 but it gave me an incompatible message when I tried to upgrade the AP. Did a quick search and it appears that the 205 and 205H are different models. Is there a firmware version 6.4.2.6-4.1.1.7 available for the 205H?
There is not yet an IAP version of the 205H.
