Contributor I
Can not connect to master controller
My Customer changed out there network switches last night.  You can ping all IAP's but 1.  Can not reach the VC, or connect to any of the IAP's via browser.
Clients are connecting and working.
Any thoughts?
Contributor I
Re: Can not connect to master controller
Here is the build and versoin of IAP.
IAP 105
Build Time:
2013-04-19 06:34:51 PDT
Version:
6.2.1.0-3.3.0.0_38115
How are the IAP getting their IP addresses ? DHCP or Static ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor I
They are getting there IP's Static.
You should probably make sure that there's no ip conflict with any other device if you are not excluding those static IPs
Is the switch serving as the DHCP server ?
Thank you
Victor Fabian
Contributor I
The IAP 105's are on a Native management VLan and passing DHCP to a DHCP server per VLAN.
Super Contributor I
Have you checked the arp tables on the switch(es) that the IAPs are connceted to? That would be a good way to see if the arp entries are present and in the right VLAN.
-Mike
Contributor I
We removed the 170.x.x.38 from the network.  Once we did that the AP's held an election and the VC came back online.
