Change from PAP when using RADIUS for management
Hi!
I'm setting up my IAP to use an external radius server for authenticating administrators. Although I can't find any way to change from PAP to encrypted protocols. Anyone know if it's possible and in that case where it's configured?
Best regards,
Chris
Christoffer Jacobsson | Aranya AB
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Re: Change from PAP when using RADIUS for management
Only the pap-based method is supported for management authentication to a radius server on Aruba Instant:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1320
The password is encrypted with the Radius Preshared key all the way to the Radius Server.  That is the single biggest determining factor of how secure your information is.
Colin Joseph
Aruba Customer Engineering
In the version of InstantOS 4.1 you can use TACACS
Thank you
Victor Fabian
Lead Mobility Architect
Thank you
Victor Fabian
Thanx for the quick replies!
