Changing WPA2 key on IAP VC with SOAP, XML or other on daily basiscluster by SOAP or other API
How is it possible to change the WPA2 key of a SSID configured on a IAP cluster by SOAP or other APIs?
A customer is doing so currently on a MSM based WiFi and would like to continue to do so by moving to IAPs respectively controller-based WiFi.
Thank you for your support in advance!
Gerhard
Re: Changing WPA2 key on IAP VC with SOAP, XML or other on daily basiscluster by SOAP or other API
It is not possible with the XML-API to change configuration on an IAP.  They would have to programmatically SSH into the IAP and change the name of the SSID.
