zda
Occasional Contributor I
Chromecast will not connect to Aruba Instant IAP-103
I have 11 IAP-103's in my corporate network, running version 6.4.2.0-4.1.1.1_46936.
I've tried everything I can think of to get Chromecast to connect to my network, to no avail.
I'm allowing all traffic and have the Broadcast Filteriing option set to ALL.
We've upgrade the Chromecast firmware to the lastest as well.
What do I have to do to get this to work? I'd find it hard to believe that Chromecast isn't compatible with Aruba Instant.
Thank you
Re: Chromecast will not connect to Aruba Instant IAP-103
It won't connect at all or you can't complete the setup?
Tim Cappalli | Aruba Security
zda
Going through the initial set up process, it's able to see my wifi network and I get to the point of entering the SSID/Password (using WPA-2 Personal), click continue and it spins for about a minute before failing to connect
zda
Thank you for your reply Tim. Any idea what the issue could be?
Do you have AirGroup Enabled ?
If you do try disabling it
Thank you
Victor Fabian
Lead Mobility Architect @WEI
zda
I'm pretty sure it's not enabled. I've attached a screenshot of my current Airgroup settings
zda
HI Tim & Victor,
Do my settings look correct?
Reading this post, it appears an updatet to 6.4 was the fix.
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Chromecast-Firewall-Settings/td-p/125637/page/2
I'm on 6.4.2.0-4.1.1.1_46936, but still no luck.
Thanks for your help
zda
To anyone reading this post; THIS IS THE FIX
1. Ensure you've factory reset the Chromecast device
2. In the Aruba GUI, go to More-->Services
3. Under the Airgroup tab, check the Enable DLNA box
4. Under AirGroup Service, enable the following:
-googlecast
-DIAL
-DLNA Media
Everything else in this section remains unchecked/disabled
5. Go through the initial Chromecast setup process.
Done. My Chromecast is now able to join my corporate wirless network
I am trying to do this for the current version of the central.arubanetworks.com.
I cannot see any optons for the DLNA settings etc.
i am able to connect the IAP205 devices if i use an open Access Point. but not with a WPA2 password.
Any ideas?
What is your problem? Are you using Aruba Central or just Instant?
