Occasional Contributor I
Cisco sw and two of IAP135
Dear Guru,
Kindly tell me your advice. This is first time to install Aruba AP.
I have two questions for this.
- How to assign IP to manage for each APs?
- I want to mange these APs with single group. Is it possible?
Cisco side
interface GigabitEthernet1/0/47
description To AP135#02
switchport trunk allowed vlan 1,101,103
switchport mode trunk
Aruba IAP 135 side (no Controller)
- Create SSID for employee
- Create SSID for guest
thanks in advance..
Re: Cisco sw and two of IAP135
When your IAP comes up initially, you should see an SSID called "instant".  Connect to it and open a broswer.  That should redirect you into the management UI.  The default credentials are admin/admin.
Once in, go to System at the top and then you should be able to set a Virtual Controller IP address to manage the cluster.
Creating your networks are done with a built in wizard as well.
Please see http://cloud.arubanetworks.com/instant-training for a complete training overview of the IAPs
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
