Occasional Contributor I
ClearPass on IAP login issue
Evening all,
I seem to be having a issue with Guest users on my IAP cluster being able logging onto our ClearPass guest Captaive Portal. The redirect from our DMZ controller to ClearPass works fine, but when guests put their username & password in, tick the T&Cs and click log In, it kicks you our and then it asks you fill it in again and it goes around in circles. I'll try and upload a video of what its doing.
Thanks in advnace
Luke
(view in My Videos)
Re: ClearPass on IAP login issue
Did you replaced the default SSL captive portal certificate on your IAP ?
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor,
Thankyou for your quick reply, no i havnt done that that. will give it a try.
Many thanks
Luke
